Exercise - Documenting a Flowchart
Revision as of 09:37, 18 July 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Adding Finishing Touches</sidebar> This exercise assumes that you have created the program described in exercises Configuring Icons and Variables and Adding Devices to a Program.
Documenting the flowchart is essential in some projects, although we have properly labelled the icons, a few comment icons helps to further explain the program and the process in further detail to aid expansion and helps others understand the system.
Load the Flowcode flowchart
(For help with this, see the article Opening an Existing Flowchart)
Benefits of documentation
Documenting your flowchart is very useful - it allows other users to understand your flowchart and allows them to learn and even add to your flowchart to help produce the final program and increase efficiency throughout the system.
Adding comments to document your flowchart is extremely easy and very useful, using comments allows you to clarify the process, purpose and function of your program and allows others to understand it so they can see what is going on and learn from it and even help to develop the program, even by suggestion a more efficient method or directly editing a icon to function more effectively.
Adding comments
  • Drag a 'Comment' icon onto the flowchart above the 'Loop' icon.
  • Double click the 'Comment' icon to open up the Comment Icon Properties dialogue box.
  • Explain the purpose of the loop and how it is the base of the process.
The loop is the base of the program as it allows the program to continually check if the switch has been pressed by repeating the process of detecting the state of the switch.
  • Add a comment above the 'Input' icon.
  • Open the icon properties by double clicking on the 'Comment' icon.
  • Describe the use of the 'Input' icon and how it reads the state of the switch.
The 'Input' icon uses a variable to read and store the state of the switch, this allows the information contained in the variable to be used to see if the switch is being pressed or not.
  • Comment and document the 'Decision' icon.
  • Describe how the 'Decision' icon detects the state of the switch and decides the next step to take.
