API Sound.SetRate
Sets the current sample rate for the sound - this will stop the playing sound
HANDLE Sounds
- The handle of the sound object to modify
ULONG Rate
- The sample rate to set
The base sample is specified in creation through Sound.Create. This call does not alter that rate, but specifies a scale factor for the samples played. Subsequent sounds played through this handle will have their wave-forms transformed using this scale factor as a step. Linear interpolation is used to smooth the waveform.
The conversion factor is calculated as (Original_Rate / Rate), meaning a Rate of zero is illegal and will cause the call to fail.
- Add to a calculation icon:
::Sound.SetRate(sounds, rate)
