API Panel.Position.SetCoords
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Sets an objects coordinates based on a position
Class hierarchy
Panel
Position
SetCoords
HANDLE Dest
HANDLE Source
The position or component to read from
BOOL
Returns true if the operation is a success, else false
This is equivalent to the call to Set, except that the scale and rotation of the position are omitted. These may be set with SetScale and SetRotation.
This call is useful for building up a position from multiple sources.
  • Add to a calculation icon:
    result = ::Panel.Position.SetCoords(dest, source)
