API Panel.LinkBar.EnableAuto
Revision as of 15:50, 1 July 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Sets whether Flowcode should automatically draw links for component object property types
Class hierarchy
Panel
LinkBar
EnableAuto
HANDLE Component
The component to enable or disable links for
BOOL Enable
True to draw default links from this component, else false
When components create properties linking components Flowcode will, by default, draw links from the source tot he destination. These are simple line-drawn links from the center of the positions.
If greater control or a different style is required, the default behavior may be switched off in the source component (the component which owns the properties) and Flowcodes default behavior can then be replaced by component-managed link bars.
  • Add to a calculation icon:
    ::Panel.LinkBar.EnableAuto(component, true)
