API System.ShowHandle
Given a handle to an object with viewable presence, shows that object on screen
HANDLE Handle
- The object to display on screen
Returns true if the operation is a success, else false
This tells Flowcode to show whatever object is represented by Handle.
The types of object that are supported are:
| Handle type | Result of this call |
| Component | Moves the camera in its current viewing plane over the components position
If the panel (system or dashboard) the component exists on is not shown, this will open that window |
| Position | Behaves as though a component, and moves the camera to look at that position |
| LinkBar | Behaves as though a component, and moves the camera to look at the center of the link |
| Point cloud | Behaves as though a component, and moves the camera to look at the center of the cloud |
| Console | Opens the console window and selects the appropriate console tab |
| Scope group/stream | Opens the data scope window to show the scope |
- Add to a calculation icon:
result = ::System.ShowHandle(handle)
