API Panel.PCloud
Revision as of 16:10, 1 July 2013 by JonnyW (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Point cloud manipulation
This class is contained within Panel.
Functions provided for this class
Create Creates a new point cloud tied to a position handle
SetPos Sets the position for the point cloud to be located at
GetPos Gets the position the point cloud is located at
SetPoints Sets the X,Y,Z point lists
SetPointsEx Sets the X,Y,Z point lists
SetGrid Sets the X,Y,Z point lists in a height-map grid
SetGridEx Sets the X,Y,Z point lists in a height-map grid
UnitScale Creates a unit scaled axis (X, Y or Z) with a center of zero and a range of two
SetColor Sets the RGB colour of the entire cloud
SetColors Sets the RGB colour of the individual points in the cloud
SetMode Sets the rendering mode of the point cloud
Update Manually refresh the screen the point cloud exists on
Constants provided for this class
Used by Create(), SetMode()
Type Name Value Description
LONG Mode_Point 0 Displays cloud as points
LONG Mode_Line 1 Displays cloud as joined lines
LONG Mode_Solid 2 Displays cloud as a solid surface
See also
