Selecting Compiler Options (AVR)
Revision as of 09:12, 20 September 2013 by ReeceL (talk | contribs)
Options list
Substitute variables used by Flowcode are the same for all platforms.
Compiler
Compiler location
Sets the location of the file controlling compilation
Default:
$(appdir)compilers\avr\batchfiles\avra.bat
Compiler parameters
Adds command line parameters when called from flowcode
Default:
$(chip:l) "$(outdir)$(target).elf" "$(outdir)$(target).c" "$(outdir)$(target).lst"
Linker/Assembler
Linker/Assembler location
Sets the location of the file controlling linking and assembly
Default:
$(appdir)compilers\avr\batchfiles\avrb.bat
Linker/Assembler parameters
Default:
<empty>
There are no default parameters
Programmer
Programmer location
Sets the location of the file controlling the programming of the target device
Default:
$(appdir)compilers\avr\batchfiles\avrc.bat
Programmer parameters
Default:
AVRDUDE $(chipalt) $(chip:l) "$(outdir)$(target).hex" "$(target).hex" 0 $(cfg0) $(cfg1) $(cfg2) $(cfg3)
Use programmer to set configuration options
This box should be left unchecked
Configuration parameters
This box should be left empty. Configuration parameters are set and downloaded from the Build > Configure menu.
Note: The above parameters assume you are using the AVRDUDE programming application and AVRISPmkII programmer. If you are using an alternative programming application or programmer you will need to consult the relevant documentation for the required parameters and settings.
File Viewer
File Viewer location
Default:
C:\Windows\Notepad.exe
File Viewer parameters
Default Assembly file viewer:
Default external program to view source files:
