API File.Buffer.WriteArray
Revision as of 15:35, 10 May 2013 by Admin (talk | contribs) (XML import of API auto-gen)
<sidebar>API contents</sidebar> Writes an array to the input stream
HANDLE FileHandle
The handle of an open file
ARRAY Data
An array of data to write to the file
ULONG Elements
Maximum number of elements to write
The default value for this parameter is: -1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.Buffer.WriteArray(filehandle, _arraydata, elements)
