Component: DSP System (DSP)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP |
DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes and reading / writing the buffers. Must be added to a project to allow the other DSP components to connect together correctly. Multiple DSP systems can be added to a single project to allow for more then 8 individual buffers.
The DSP System component is basically a buffer manager for the other DSP components to reference.
The DSP system does not perform any specific DSP function by itself.
For examples of how to use the DSP System component please refer to the other functional DSP components.
TickSpecificBuffer
Moves to the next segment of a specific DSP system buffer.
Returns the first buffer index if the end of a buffer has been reached.
- BYTE idx
- Specifies which buffer index to increment (0:A - 7:H)
SetBuffer_Idx
Allows manual control over the buffer index.
- BYTE BufferIdx
- Specifies which buffer to control (0:A - 7:H)
- UINT Idx
- Raw index value to assign to the buffer
SetBuff
Adds a value into the start of the buffer specified by the idx parameter.
- BYTE Idx
- UINT Data
GetBuff
Gets a value from the end of the buffer specified by the idx parameter
- BYTE Idx
TickAllBuffers
Moves to the next segment of each DSP system buffer.
Initialises the DSP System allowing DSP components to run correctly.
Simulation macro reference
Buffer Count
This property is of type Fixed list of ints and can be referenced with the variable name buffer_count.
Number of DSP buffers to allocate memory for
Simple Mode
This property is of type True or false and can be referenced with the variable name simple_mode.
Simple mode
Yes - all buffers are the same type and length
No - all buffers are configured individually
Buffer A Name
This property is of type Line of text and can be referenced with the variable name buff_a_name.
The name assigned to buffer A
Buffer B Name
This property is of type Line of text and can be referenced with the variable name buff_b_name.
The name assigned to buffer B
Buffer C Name
This property is of type Line of text and can be referenced with the variable name buff_c_name.
The name assigned to buffer C
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_a_depth.
The maximum size of each value in the buffer:
8-bit = 0 to 255 or -128 to 127
16-bit = 0 to 65535 or -32768 to 32767
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_a_sign.
The typecast sign allowing the values in the buffer to represent negative values:
Signed = -128 to 127 or -32768 to 32767
Unsigned = 0 to 255 or 0 to 65535
Size
This property is of type Signed integer and can be referenced with the variable name buff_a_size.
The number of individual values inside the buffer
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_b_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_b_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_b_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_c_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_c_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_c_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_d_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_d_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_d_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_e_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_e_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_e_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_f_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_f_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_f_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_g_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_g_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_g_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_h_depth.
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_h_sign.
Size
This property is of type Signed integer and can be referenced with the variable name buff_h_size.
Bit Depth
This property is of type Fixed list of ints and can be referenced with the variable name buff_simp_depth.
The maximum size of each value in the buffers:
Sign
This property is of type Fixed list of ints and can be referenced with the variable name buff_simp_sign.
The typecast sign allowing the values in the buffers to represent negative values:
Size
This property is of type Signed integer and can be referenced with the variable name buff_simp_size.
The number of individual values inside the buffers
