API Component.Property.SetFilter
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Sets a components property filter string for lists, files, etc
Class hierarchy
Component
Property
SetFilter
HANDLE Handle
The component handle of the property owner
STRING Property
The textual name of the property
STRING Value
The value to update the property filter with
Sets the filter field of a property. The filter field is a text block whose use in Flowcode is decided by the properties type.
The field, for example, may be used to hold a list of items in a list-type property, or a file-filter in a file selection property. See the list of property types for further details.
No checks are done for validation on the field, and any text desired may be entered into this. However, it is the callers responsibility to only add text with the correct format if a format is required..
  • Add to a calculation icon:
    ::Component.Property.SetFilter(handle, "property", "value")
