API Panel.PCloud.UnitScale
<sidebar>API Contents</sidebar> Creates a unit scaled axis (X, Y or Z) with a center of zero and a range of two
FLOAT[] Axis
- The X, Y or Z axis to adjust
ULONG Offset
- The first item in the array to adjust
LONG ArrayStep
- The number of elements from the first to the second
- The default value for this parameter is: 1
ULONG Elements
- The number of points to adjust
FLOAT OrigOffset
- Returns the center of the original object
- This parameter is returned back to the caller
FLOAT OrigRange
- Returns the range of the original object
- Add to a calculation icon:
::Panel.PCloud.UnitScale(_arrayaxis, offset, arraystep, elements, return_origoffset, return_origrange)
