Component: RF ISM (EB063, MRF49XA) (Wireless)
| Author | Matrix Ltd. |
| Version | 1.1 |
| Category | Wireless |
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device. Also available in the form of the EB063 RF E-block.
The example attempts to send and receive data from a remote board. You will need two RF modules to allow the communications to work.
The example can be used to drive both ends of the RF communications as it will send out data but also print out any data received onto the LCD. Pins RA0 and RA1 can be used for diagnostics on the program.
SetSyncPattern
Allows the sync pattern to be modified during runtime to allow for switching between several different RF connections.
- BYTE Mode
- Switches on or off the extended sync functionality
- BYTE Pattern
- The bit pattern used for the standard sync mode
ReceiveByte
Puts the RF module in data mode and attempts to receive a single byte from the RF connection. Only packets containing a single data byte will be accepted.
- BYTE Timeout
- Specifies how many milliseconds to wait for valid data before returning.
SendString
Puts the RF module in data mode and transmits a packet containing the data string through the RF connection.
A packet consists of Sync information, Data and Checksum.
- STRING Data
TXTune
Used to specify and adjust the RF transmitter properties during runtime.
- BYTE Deviation
- Specifies the transmit FSK frequency deviation - Range 0 - 15
- BYTE Power
- Specifies the transmitter power - Range 0 - 7
RXTune
Used to specify and adjust the RF receiver properties during runtime.
- BYTE Bandwidth
- Specifies the Rx bandwidth - Range 1- 6
- BYTE Gain
- Specifies the Rx gain - Range 0 - 3
- BYTE Threshold
- Specifies the Rx signal to noise threshold - Range 0 - 5
SetBufferData
Allows a value to be loaded into the transmit buffer,
- BYTE Index
- The current location in the transmit buffer starting from 0
- BYTE Data
- The data value to pass
UpdateCenterFrequency
Allows the RF center frequency to be adjusted during runtime to allow multiple RF channels to be scanned or multiplexed.
- UINT Frequency
- Specifies the new center frequency value - Range 96 - 3903
FSKWrite
Writes to the FSK (frequency shift key) data pin.
- BYTE State
GetDataCount
Returns the number of bytes in the received data buffer.
SendBuffer
Sends the contents of the transmit buffer.
- BYTE Count
- Specifies how many bytes to transfer from the transmit buffer
SendByte
Puts the RF module in data mode and transmits a packet containing a single data byte through the RF connection.
- BYTE Data
ActivateTXMode
Enables the transmitter interface, allowing data to be sent.
The receiver interface is automatically disabled.
SetDataRate
Allows the RF data rate to be adjusted during runtime.
- BYTE Rate
- Specifies the new data rate
ActivateRXMode
Enables the receiver interface, allowing data to be received.
The transmitter interface is automatically disabled.
FSKRead
Reads the FSK (frequency shift key) data pin.
ReadRXSignalStrength
Returns the current received signal strength.
Uninitialise
Powers down the RF module. The module must be re-initialised before it can be used again.
CheckBuffer
Checks for incoming data for a specific period of time.
Returns a value greater then 250 to indicate a failure.
Returns the length of the incoming data buffer to indicate success.
- BYTE Timeout
- Time to wait before returning no data available
GetBufferData
Returns a value from the incoming receive data buffer.
- BYTE Index
- Specifies which position in the buffer to read data from
ReceiveString
Puts the RF module in data mode and attempts to receive a string of bytes from the RF connection.
- BYTE Length
- Specifies the maximum number of bytes to try and receive
- BYTE Timeout
Starts up and configures the RF module ready for use.
The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
Simulation macro reference
Module Frequency
This property is of type Fixed list of ints and can be referenced with the variable name module_freq.
Module frequency - must be matched with the specific RF transciever being used.
Center Frequency (96-3903)
This property is of type Signed integer and can be referenced with the variable name cent_freq.
Specifies the default RF center frequency
Center Frequency (MHz)
This property is of type Floating point and can be referenced with the variable name cent_freq_cal.
Calculation to work out the approx actual frequency
Data Mode
This property is of type Fixed list of ints and can be referenced with the variable name data_mode.
Specifies if the module will send data packets (Byte) or FSK bits (Bit)
Data Buffer Size (Max)
This property is of type Signed integer and can be referenced with the variable name buffer_size.
Maximum number of bytes that can be loaded into a single data packet
Rate Divider 1
This property is of type Fixed list of ints and can be referenced with the variable name data_div1.
Data rate prescaler 1 - Coarse control
Rate Divider 2 (0-127)
This property is of type Signed integer and can be referenced with the variable name data_div2.
Data rate prescaler 2 - Fine control
Max Throughput (Kb/s)
This property is of type Floating point and can be referenced with the variable name baud_rate.
Calculated max data throughput if the data is 100% active
Data Rate Value
This property is of type Unsigned integer and can be referenced with the variable name DataRateValue.
Actual default value passed to the data rate control
Sync Pattern
This property is of type Signed integer and can be referenced with the variable name sync_pattern.
Default sync pattern used by the standard sync in byte data mode.
Extended Sync
This property is of type Fixed list of ints and can be referenced with the variable name extended_sync.
Selects if an additional fixed sync byte is to be used.
Bandwidth
This property is of type Fixed list of ints and can be referenced with the variable name rx_bandwidth.
Controls the receiver bandwidth, the higher the value the bigger the datarate that can be acheived but the fewer channels that can co-exist
Gain
This property is of type Fixed list of ints and can be referenced with the variable name rx_gain.
Controls the receiver gain - the amount to amplify the incoming signal before processing
Threshold
This property is of type Fixed list of ints and can be referenced with the variable name rx_threshold.
The signal to noise threshold used to control the sensitivity
Bandwidth
This property is of type Fixed list of ints and can be referenced with the variable name tx_bandwidth.
Controls the transmitter bandwidth, i.e. the frequency either side of the center frequency to use for the RF communications
Power
This property is of type Fixed list of ints and can be referenced with the variable name tx_power.
The amount of power to use when transmitting
SPI Channel
This property is of type Fixed list of ints and can be referenced with the variable name Channel.
FSEL Pin
This property is of type Single digital pin and can be referenced with the variable name fsel_pin.
MOSI Pin
This property is of type Single digital pin and can be referenced with the variable name mosi_pin.
MISO Pin
This property is of type Single digital pin and can be referenced with the variable name miso_pin.
SCK Pin
This property is of type Single digital pin and can be referenced with the variable name sck_pin.
CS Pin
This property is of type Single digital pin and can be referenced with the variable name cs_pin.
