Component: IrDA (EB012, MCP1250, MCP2120) (Wireless)
| Author | Matrix Ltd. |
| Version | 1.1 |
| Category | Wireless |
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface.
Receive
Basic example which waits for any incoming data and then displays the data on the LCD.
SendChar
- INT Char
ReceiveChar
- INT Timeout
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
INTERFACE
This property is of type Fixed list of ints and can be referenced with the variable name INTERFACE.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
