API Sound.LoadWav
<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
Class hierarchy
- Sound
- LoadWav
STRING Filename
- The formatted file to load into memory
BYTE[] Buffer
- A buffer to write the wave data to
UINT SampleFormat
- This parameter is returned back to the caller
- Variable to receive the format of the samples
ULONG Elements
- Variable to receive the number of sample elements to play
FLOAT SampleRate
- Variable to receive the wave source sample rate
- Add to a calculation icon:
result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
