API Scope
Revision as of 11:04, 1 September 2014 by BenR (talk | contribs)
<sidebar>API Contents</sidebar> Data scope additions
Functions provided for this class
AddGroup Adds a group to the scope to which streams may be added
AddStream Adds a stream to the given group suitable for inputs and operations
AddBuffer Adds a fixed-view stream to the given group suitable for inputs and operations
Rename Renames the given scope group, stream or buffer
AddPort Adds an input to the stream from a port
AddAnalog Adds an input to the stream from an analog channel
AddCustom Adds an input to the stream from a custom injection
AddOp Adds an operation to act on the inputs of the stream
ClearOps Clears all inputs and operations from the given stream
SetBuffer Sets the contents of a snapshot stream
SetCustom Sets one of 32 custom analog values for the group
GetSnapshot Gets a block of the output stream with each input sample operated on, returns number of samples read
GetOutputBlock Gets a block of the output stream
FindOutput Searches back through the output history for a value, returns offset of found sample from TimeUS, 0 if not found
FindBaud Attempts to calculate the baud given a series of transitions for the stream, returns calculated baud
AddOverlay Adds a packet overlay to the stream at a given offset from the current time
AddOverlays Adds overlay packets to the stream by decoding the stream contents
ClearOverlays Clears existing overlay packets from the stream
ClearAllOverlays Clears all existing overlay packets from the stream
Constants provided for this class
Used by AddOp()
Type Name Value Description
LONG Op_Bound 1 Bound the current value to the expected range of the input
LONG Op_Scale 2 Divide the current value to the expected range of the input
LONG Op_Xor 3 Exclusive-or with the provided integer argument
LONG Op_AndNot 4 Clear the bits in the provided integer argument
LONG Op_And 5 Isolate only the bits in the provided integer argument
LONG Op_Orr 6 Set the bits in the provided integer argument
LONG Op_Not 7 Invert (ones-compliment) the current input
LONG Op_Add 8 Add the argument to the current input
LONG Op_Sub 9 Subtract the argument from the current input
LONG Op_Mul 10 Multiply the argument by the current input
LONG Op_Div 11 Divide the current input by the argument
LONG Op_Pow 12 Raise the input to the power of the argument
LONG Op_Neg 13 Negate (twos compliment) the current input
LONG Op_Recip 14 Perform the reciprocal on the current input
LONG Op_Sqrt 15 Perform a square root on the current input
LONG Op_Ln 16 Perform a natural logarithm on the current input
LONG Op_Ln2 17 Perform a base-2 logarithm on the current input
LONG Op_Cos 18 Convert the input to its cosine value (input is in radians)
LONG Op_Sin 19 Convert the input to its sine value (input is in radians)
LONG Op_Tan 20 Convert the input to its tangent value (input is in radians)
LONG Op_Int 21 Convert the input from a float to an integer (using the floor function)
Used by FindOutput()
LONG Find_Lower 1 Match a search when output is lower than the target value
LONG Find_Equal 2 Match a search when output is equal to the target value
LONG Find_Higher 4 Match a search when output is greater than the target value
LONG Find_LowHigh 8 Match a search when output goes lower to higher than the target
LONG Find_HighLow 16 Match a search when output goes higher to lower than the target
Used by AddOverlays()
LONG Overlay_LSBF 1 Flags least-significant bit first, else most-significant bit first
LONG Overlay_Invert 2 Flags to invert the bits in a packet before calculating the packet value
See also
