API File
Jump to navigationJump to search<sidebar>API contents</sidebar> File reading and writing operations
Sub-classes provided for this class
| Buffer | Reads writes and monitors circular buffers |
| NVM | Reads from a file as though a block of NVM |
Functions provided for this class
| AbsPath | Gets an absolute path from a relative filename |
| RelPath | Gets an relative path from an absolute filename |
| CreateDir | Creates a directory structure |
| GetType | Finds the type of a file: 0=Unknown, 1=File, 2=Dir, 4=Disk |
| GetSize | Gets the number of bytes in the file, by handle or name |
| Delete | Deletes the file or directory structure |
| Create | Creates the new file as a standard stream |
| Open | Opens the existing file as a standard stream |
| ReadArray | Reads an array from the file, returns elements read |
| WriteArray | Writes an array to the file |
| SetPos | Sets the position of the next read or write in the file |
| GetPos | Gets the position of the next read or write in the file |
| Flush | Writes all unwritten data to the file in one block |
Constants provided for this class
| LONG | 0 |
| LONG | 1 |
| LONG | 2 |
No examples available
