API File.Buffer.Open
<sidebar>API contents</sidebar> Opens the existing file as a circular buffer
Class hierarchy
- File
- Buffer
- Open
- Buffer
STRING Filename
- The name of an existing file to open
BOOL Write
- Set to enable write access
BOOL Monitor
- Set to enable monitoring of the file
- Add to a calculation icon:
result = ::File.Buffer.Open("filename", true, false)
