MLoader:Recent Changes
Revision as of 15:23, 22 January 2015 by SteveT (talk | contribs)
(Click here to return to the main mLoader page)
New in v3.2.1.5
Released Jan 2015
General
  • Added return code for automation
  • Corrected errors in chip CSV files (EEPROM locations, chipid)
  • Improvements to stability
  • Added timestamp output to trace functions
  • Fixed various memory leaks
User Interface
  • Corrected version number display
  • Updated help file and moved to wiki
  • Added links to website
  • Added chip list for dsPIC/PIC24 devices
  • Fixed autoscroll of output window
  • Improvements to UI (buttons correctly disabled for appropriate targets)
  • Improved reporting of errors
  • Added missing menu items
  • Progress bar functionality extended to other long operations
  • Added a wait cursor for long operations
  • User can now retry when problems occur in non-UI mode
  • Added 'wrong chip' message if unexpected target is detected
Programming
  • Fixed problems with ECIO/MIAC/etc. devices
  • Fixed problems programming EB006 (legacy / v9) boards
  • Added full support for dsPIC33E device on EB091
  • Chip autodetect functionality added (EB006 / EB064)
  • EEPROM reading added when receiving file
  • UI-mode tx/rx functions hold chip in programming mode (consistent across targets)
  • Added support for 18FxxK22 and 18FxxK50 devices
Known Issues
  • mLoader is incompatible with the following chips:
    • 10Fxxx
    • 12F5xx
    • 16F5x and 16F5xx
    • 16F707 and 16F716
    • 16F72x and 16F72xA
    • 18FxxJxx
  • The 18F13K50 and 18F14K50 chips may not work with older versions of EB006 - please contact technical support via the forum for more information.
