API Panel.Position.GetEuler
Revision as of 21:16, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Returns the positions euler angles in {P,Y,R} array
===Class hierarchy===API
Panel
Position
GetEuler
HANDLE Handle
The position or component to read
HANDLE Target
The position or component to convert relative to
FLOAT[]
  • Declare a variable 'result' of type FLOAT[]
  • Add to a calculation icon:
    result = ::Panel.Position.GetEuler(handle, target)
