API Sound.Create
Revision as of 21:17, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Creates a sound object that data can be played through
===Class hierarchy===API
Sound
Create
ULONG SampleRate
The number of samples per second
The default value for this parameter is: 44100
BYTE SampleBits
The number of bits per sample - either 8 or 16
The default value for this parameter is: 8
BOOL Stereo
True to treat each pair of samples as a stereo sample
HANDLE
  • Add to a calculation icon:
    result = ::Sound.Create(samplerate, samplebits, false)
