API Sound.Queue
Revision as of 21:17, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Queues a sound for playing
===Class hierarchy===API
Sound
Queue
HANDLE Sounds
The handle of the sound object to queue to
ARRAY Data
The array to play data from
ULONG Offset
The element in the array to start at
ULONG Elements
The number of elements to play
The default value for this parameter is: -1
FLOAT RateMul
A multiplier to the sounds sample rate
The default value for this parameter is: 1
BOOL
  • Add to a calculation icon:
    result = ::Sound.Queue(sounds, _arraydata, offset, elements, ratemul)
