Component: Bluetooth v2 (EB024, Generic AT) (Wireless)
| Author | Matrix Ltd. |
| Version | 1.4 (Release) |
| Category | Wireless |
Bluetooth v2 (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware channel.
SetPairKey
Sets the 4 digit Bluetooth pair key based on a string of numbers.
e.g. "1234"
Returns 0 to indicate success
- <- STRING PairKey
- Key to use as the Pair key, e.g. "1234" or "0000"
ReceiveByte
Receives a single data byte from the Bluetooth module.
0xFF signifies no data available.
- BYTE Timeout
- Amount of time to wait in milliseconds 0=Wait forever
SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
- <- STRING Command
- BYTE SendCR
ReadString
Copies the incoming data from the data string array to a local string variable.
- BYTE NumBytes
SaveSettings
Saves the current settings to firmware using the AT&W command followed by the ATZ command.
SendByte
Sends a single data byte out to the Bluetooth module.
- BYTE Data
SetMode
Sets the bluetooth mode to be discoverable and or connectable.
Returns 0 for success.
- BYTE Discoverable
- 0 = Not Discoverable, 1 = Discoverable
- BYTE Connectable
- 0 = Not Connectable, 1 = Connectable
RestoreFactorySettings
Restores the factory settings to firmware using the AT&F* command.
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
Simulation macro reference
Device Name
This property is of type Line of text and can be referenced with the variable name DeviceName.
Sets the friendly name of the Bluetooth device.
Pair Key
This property is of type Line of text and can be referenced with the variable name PairKey.
Restore Defaults
This property is of type True or false and can be referenced with the variable name InitDefs.
Is the Bluetooth module reset to factory settings at startup?
Discoverable
This property is of type True or false and can be referenced with the variable name InitDisc.
Is the Bluetooth module discoverable by default?
Connectable
This property is of type True or false and can be referenced with the variable name InitConn.
Is the Bluetooth module connectable by default?
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Maximum number of scripts to store in the device's ROM
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
ASCII based AT command data stored in ROM and used when sending script 1
String Array Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responses from the BT module.
Default 40
This property is of type Fixed list of ints and can be referenced with the variable name baud.
Theoretical number of digital bits that can be send or received a second.
Theoretical because it is unlikely you will be constantly sending or receiving data 100% of the time.
Flow Control
This property is of type True or false and can be referenced with the variable name flow_control.
When enabled adds two extra pins to help control the flow of data between the device and the remote device.
Expect Echo
This property is of type True or false and can be referenced with the variable name expect_echo.
Sets if we expect an echo of any data we send out to the GSM modem.
Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
This property is of type Fixed list of ints and can be referenced with the variable name channel.
Onboard UART peripheral to use to perform serial commands.
Software mode not available as code currently requires hardware receive interrupt in order to work correctly.
TX Pin
This property is of type Single digital pin and can be referenced with the variable name tx_pin.
UART Transmit Pin
RX Pin
This property is of type Single digital pin and can be referenced with the variable name rx_pin.
UART Receive Pin
RTS Pin
This property is of type Single digital pin and can be referenced with the variable name rts_pin.
Request To Send Flow Control Pin
CTS Pin
This property is of type Single digital pin and can be referenced with the variable name cts_pin.
Clear To Send Flow Control Pin
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name Reset.
Textual label shown on the component I/O flasher
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
