Component: Button helper (Helpers)
| Author | Matrix Ltd |
| Version | 1.1 (Release) |
| Category | Helpers |
- 1 Button helper component
- 2 Examples
- 3 Downloadable macro reference
- 4 Simulation macro reference
- 4.1 GetStateFor
- 4.2 Clear
- 4.3 SetDisabledPos
- 4.4 SetEnabledPos
- 4.5 SetAxis
- 4.6 SetDisabledPosFor
- 4.7 GetTarget
- 4.8 GetState
- 4.9 Register
- 4.10 SetNotify
- 4.11 SetLatchingFor
- 4.12 SetMode
- 4.13 SetEnabledPosFor
- 4.14 SetPivotPosFor
- 4.15 SetModeFor
- 4.16 SetMovement
- 4.17 SetAxisFor
- 4.18 SetPivotPos
- 4.19 SetAutoReset
- 4.20 SetLatching
- 4.21 Unregister
- 4.22 SetMovementFor
- 5 Property reference
A button overlay that allows any object to behave like a button
This component does not contain any downloadable macros
GetStateFor
Returns true if the button is depressed, else false
- HANDLE Target
- BOOL : Returns true if the operation is a success, else false
Clear
Clears all objects from the lists
This leaves no links for the button helper
SetDisabledPos
Sets the position of the released button
- HANDLE PositionHandle
- A handle to the position of the depressed location
SetEnabledPos
Sets the position of the depressed button
SetAxis
Sets the movement axis as an Axis_... constant
- BYTE Axis
- Movement axis to set to, default 4
SetDisabledPosFor
Sets the disabled position for an object
- HANDLE Target
- HANDLE Position
GetTarget
Gets the target handle the property links to
- HANDLE : The component linked to the control by property
GetState
Register
Adds the object to the list if not already there
- HANDLE Target
SetNotify
Sets the object to notify when the button is pressed or released
- HANDLE Handle
- The handle of the object - 0 to use the caller object
- ULONG Ident
- The identifier to send in the System.Notify message
SetLatchingFor
Sets whether the button is depressed when the mouse is released
- HANDLE Target
- BOOL Enabled
SetMode
Sets the animation mode for the button
- BYTE Mode
- 0=User, 1=Up/Down, 2 = Lever
SetEnabledPosFor
Sets the enabled position for an object
- HANDLE Target
- HANDLE Position
SetPivotPosFor
Sets the position the lever rotates around for an object
- HANDLE Target
- HANDLE Position
SetModeFor
- HANDLE Target
- The target object, 0 for 'set default'
- BYTE Mode
SetMovement
Sets the movement in units or PI/16 steps for the button
- FLOAT Move
- Movement to set to - default is 4
SetAxisFor
- HANDLE Target
- BYTE Axis
SetPivotPos
Sets the position of the object the lever rotates around
SetAutoReset
Sets the state of the auto-reset flag
If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
- BOOL State
- Set true to reset to off on sim stop, else false to retain state
SetLatching
- BOOL Enabled
Unregister
Removes the object to the list if present
- HANDLE Target
SetMovementFor
- HANDLE Target
- FLOAT Move
- Movement to set to, default 4
Host component
This property is of type Panel object and can be referenced with the variable name Target.
Lever pivot
This property is of type Panel object and can be referenced with the variable name Pivot.
