Component: MIAC Advanced (MIAC: Addon Modules)
Revision as of 15:45, 20 July 2016 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category MIAC: Addon Modules
Image MIAC Advanced component
Advanced Addon for MIAC System
UART_ReceiveChar
BYTE Timeout
UINT
PWM_Enable
Enable the PWM on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
MI2C_Send_Byte_Transaction
BYTE Device_ID
BYTE AddrH
BYTE AddrL
BYTE Data
RTC_Read_Time
BYTE HMS
BYTE
RTC_Set_Date
BYTE Day
BYTE Month
BYTE Year
SPI_Uninit
This macro has no parameters
MI2C_Stop
DAC_WriteChannels
Wrtie values to both DAC Channels
INT ChannelA
INT ChannelB
UART_SendString
<- STRING Text
This parameter may be returned back to the caller
SPI_Init
RTC_Reg_Write
BYTE Reg
BYTE Value
MI2C_Restart
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
BYTE State
RTC_Read_Date
BYTE DMY
BYTE
SPI_Get_Char
BYTE
UART_Initialize
SPI_Send_Char
BYTE Char
MI2C_Transmit_Byte
BYTE Data
BYTE
Sensor_Read
BYTE Sensor
BYTE HiRes
INT
MI2C_Init
MI2C_Receive_Byte
BYTE Last
BYTE
PWM_Disable
Disable the PWM on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
RTC_Reg_Read
BYTE Reg
BYTE
MI2C_Receive_Byte_Transaction
BYTE Device_ID
BYTE AddrH
BYTE AddrL
BYTE
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
BYTE Terminal
BYTE Value
BYTE
DAC_Write
BYTE Channel
INT Value
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
BYTE Terminal
Terminal number to be read
UINT
Initialize
Forces a software reset on the module
RTC_Get_Data
RTC_Set_Time
BYTE Hour
BYTE Min
BYTE Sec
UART_ReceiveString
BYTE Timeout
BYTE NumBytes
STRING
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
BYTE Duty
Duty cycle (8 bit value)
MI2C_Start
DigitalInput
Read the value of a terminal
BYTE Terminal
BYTE
UART_SendChar
UINT Character
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
Period Overflow
This property is of type Unsigned integer and can be referenced with the variable name PERIOD.
Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PRESCALER.
Frequency (KHz)
This property is of type Floating point and can be referenced with the variable name PWM_FREQ.
Period (uS)
This property is of type Floating point and can be referenced with the variable name PWM_PERIOD.
This property is of type Unsigned integer and can be referenced with the variable name BAUD1.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name BITS1.
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RET1.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO1.
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOW1.
Rate
This property is of type Fixed list of ints and can be referenced with the variable name SPI_RATE.
Prescale option selector
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name CKP.
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name CKE.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SMP.
Data bit read sample point
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name I2C_BAUD.
Slew Rate Control
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SRC.
Slew Rate Control Enabled or Disabled
SMBus Inputs
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SMB.
When Enabled input logic thresholds are compliant with SMBus specification
