Component: MIAC Basic (MIAC: Addon Modules)
Revision as of 15:45, 20 July 2016 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category MIAC: Addon Modules
Image MIAC Basic component
Basic Addon expansion module for MIAC System
PWM_Enable
Enable the PWM on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
BYTE State
PWM_Disable
Disable the PWM on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
BYTE Terminal
BYTE Value
BYTE
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
BYTE Terminal
Terminal number to be read
UINT
Initialize
Forces a software reset on the module
This macro has no parameters
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
BYTE Channel
PWM Channel 1 or 2
BYTE Duty
Duty cycle (8 bit value)
DigitalInput
Read the value of a terminal
BYTE Terminal
BYTE
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
Period Overflow
This property is of type Unsigned integer and can be referenced with the variable name PERIOD.
Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PRESCALER.
Frequency (KHz)
This property is of type Floating point and can be referenced with the variable name PWM_FREQ.
Period (uS)
This property is of type Floating point and can be referenced with the variable name PWM_PERIOD.
