Component: MIAC Industrial (MIAC: Addon Modules)
| Version | 1.0 (Release) |
| Category | MIAC: Addon Modules |
MIAC Industrial component
MIAC Industrial Addon component for MIAC System. Add (WIZ810MJ) TCP/IP or Webserver component to the panel to add functionality.
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
RS485_Send
Send a character to RS485.
Returns 0 for successful acknowledgment, otherwise:
0x8000 Unexpected acknowledgment ID
0xa000 Insufficient data in acknowledgment
0xc000 Unexpected CAN ID acknowledgment
0xe000 Timeout, no acknowledgment received
- INT Char
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
RS485_Initialize
Initialize the parameters for the RS485 communication channel
- BYTE DataSize
- Bit width, 8 or 9 bits
- INT BaudRate
RS485_Receive
Wait up to Timeout (mS) for a character to be received.
Returns the character if successful, otherwise:
0xe000 Timeout, nothing received
- UINT Timeout
- Timeout in mS
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
Initialize
Forces a software reset on the module
DigitalInput
Read the value of a terminal
- BYTE Terminal
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
