Component: MIAC Serial (MIAC: Addon Modules)
| Version | 1.0 (Release) |
| Category | MIAC: Addon Modules |
Serial Addon expansion module for MIAC System
UART_ReceiveChar
- BYTE Timeout
FAT_OpenFile
- <- STRING Filename
PWM_Enable
Enable the PWM on Channel 1 or 2
- BYTE Channel
- PWM Channel 1 or 2
MI2C_Send_Byte_Transaction
- BYTE Device_ID
- BYTE AddrH
- BYTE AddrL
- BYTE Data
SERIAL_ReceiveChar
- BYTE Timeout
FAT_Init
SERIAL_SendChar
- UINT Character
SPI_Uninit
MI2C_Stop
UART_SendString
- <- STRING Text
FAT_ScanCurrentFolder
- UINT idx
- BYTE type
- Scan type
SPI_Init
FAT_AppendStringToFile
- <- STRING Text
MI2C_Restart
FAT_OpenFolder
- <- STRING Folder
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
SPI_Get_Char
UART_Initialize
FAT_MoveToNextFileSector
- BYTE force
- force next sector
FAT_ReadByteFromScan
- UINT idx
SPI_Send_Char
- BYTE Char
FAT_ReadFileLength
MI2C_Transmit_Byte
- BYTE Data
FAT_CreateFile
MI2C_Init
MI2C_Receive_Byte
- BYTE Last
PWM_Disable
Disable the PWM on Channel 1 or 2
- BYTE Channel
SERIAL_ReceiveString
- BYTE Timeout
- BYTE NumBytes
FAT_WriteFileSector
SERIAL_SendString
- <- STRING Text
MI2C_Receive_Byte_Transaction
- BYTE Device_ID
- BYTE AddrH
- BYTE AddrL
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
FAT_ReadByteFromBuffer
- UINT address
FAT_ReadFileSector
FAT_WriteByteToBuffer
- UINT address
- BYTE data
SERIAL_Initialize
FAT_DeleteFile
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
Initialize
Forces a software reset on the module
UART_ReceiveString
- BYTE Timeout
- BYTE NumBytes
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
- BYTE Duty
- Duty cycle (8 bit value)
MI2C_Start
DigitalInput
Read the value of a terminal
- BYTE Terminal
UART_SendChar
- UINT Character
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
Period Overflow
This property is of type Unsigned integer and can be referenced with the variable name PERIOD.
Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PRESCALER.
Frequency (KHz)
This property is of type Floating point and can be referenced with the variable name PWM_FREQ.
Period (uS)
This property is of type Floating point and can be referenced with the variable name PWM_PERIOD.
This property is of type Unsigned integer and can be referenced with the variable name BAUD1.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name BITS1.
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RET1.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO1.
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOW1.
Rate
This property is of type Fixed list of ints and can be referenced with the variable name SPI_RATE.
Prescale option selector
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name CKP.
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name CKE.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SMP.
Data bit read sample point
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name I2C_BAUD.
Slew Rate Control
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SRC.
Slew Rate Control Enabled or Disabled
SMBus Inputs
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SMB.
When Enabled input logic thresholds are compliant with SMBus specification
This property is of type Unsigned integer and can be referenced with the variable name BAUD2.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name BITS2.
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RET2.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO2.
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOW2.
