Component: MIAC Zigbee Router (MIAC: Addon Modules)
Revision as of 15:47, 20 July 2016 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category MIAC: Addon Modules
Image MIAC Zigbee Router component
MIAC Zigbee Router Addon component for MIAC System. Add the Zigbee component to the panel to add functionality.
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
BYTE State
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
BYTE Terminal
BYTE Value
BYTE
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
BYTE Terminal
Terminal number to be read
UINT
Initialize
Forces a software reset on the module
This macro has no parameters
DigitalInput
Read the value of a terminal
BYTE Terminal
BYTE
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
