Component: Modbus Master (Comms: System)
| Author | Matrix Ltd. |
| Version | 1.2 (Release) |
| Category | Comms: System |
Modbus Master component
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount.
Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT SlaveID
- The ID of the MODBUS slave
- UINT RegAddress
- Address: 0=40001, 1=40002, ...
- UINT RegCount
- Number of consecutive registers to read, starting from RegAddress
ForceSingleCoil
This command writes the contents of a discrete coil at the location CoilAddress.
- UINT SlaveID
- UINT CoilAddress
- Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- BYTE CoilState
- 0=Off, 1=On
GetResponse
Collects as much incoming data as possible and stored into the response buffer. The number of bytes received will be stored into location 0 of the response buffer.
Return value indicates validity of incoming CRC. 0 = OK, 1 = CRC fail, 255 = No Data
ReadCoilStatus
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount.
- UINT SlaveID
- UINT CoilAddress
- UINT CoilCount
- Number of consecutive coils to try and read
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE Index
- 0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, .....
ReadInputStatus
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount.
- UINT SlaveID
- UINT DataAddress
- Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT DataCount
- Number of consecutive inputs to read, starting from RegAddress
PresetSingleRegister
This command writes the contents of a analogue output holding registerl at the location RegAddress.
- UINT SlaveID
- UINT RegAddress
- UINT RegValue
- Value to send to the selected register
ReadInputRegister
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount.
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
PresetMultipleRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount .
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
- Number of consecutive registers to write, starting from RegAddress
- UINT RegValue
- Array of values to send to the registers
Starts up the UART to allow communications
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
UART channel to specify a software channel or an onboard hardware channel
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
UART transmit pin
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
UART receive pin
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
Data rate in bits per second
Bus
This property is of type Fixed list of ints and can be referenced with the variable name BusType.
Specifies the bus mode being used,
RS232 allows you to connect a single master node to a single slave node.
RS485 allows you to connect a single master node to multiple slave nodes.
Frame Type
This property is of type Fixed list of ints and can be referenced with the variable name FrameType.
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
Slave ID Bytes
This property is of type Unsigned integer and can be referenced with the variable name AddressBytes.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to COM port hardware or the the data injector components.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name COM_port.
COM port assigned to allow the simulation to communicate with actual Modbus hardware.
