Component: USB Serial (Comms: USB)
| Author | Matrix Ltd. |
| Version | 1.6 (Development) |
| Category | Comms: USB |
USB Serial component
Component to create and communicate using a standard CDC type COM port. Compatible with simulation and USB enabled microcontroller devices PIC/dsPIC/AVR.
SendString
Sends the specified data string to the host
- <- STRING Data
- Data string to send to the host
ReadString
Retreives a string from the incoming data buffer. If data is available then the macro will return straight away. If there is no data available then the macro waits up the the period specified by the timeout before returning the value 255.
- BYTE Timeout_ms
- Length of time to wait before timing out
- BYTE Length
- Maximum number of bytes to try and read
SendByte
Sends the specified data byte to the host
- BYTE data
- Data byte to send to the host
ReadByte
Retreives the byte from the incoming data buffer. If data is available then the macro will return straight away. If there is no data available then the macro waits up the the period specified by the timeout before returning the value 255.
- BYTE Timeout_ms
- Number of milliseconds to wait before timing out
Starts up the USB communications and attempts to enumerate.
Returns 0 for a successful startup or 255 for a enumeration timeout.
Simulation macro reference
Vendor ID
This property is of type Signed integer and can be referenced with the variable name vendor_ID.
USB VID
Product ID
This property is of type Signed integer and can be referenced with the variable name product_ID.
USB PID
Device Name
This property is of type Line of text and can be referenced with the variable name dev_name.
USB Device Name
Manufacturer
This property is of type Line of text and can be referenced with the variable name dev_manufacturer.
USB Manufacturer
Major Version
This property is of type Signed integer and can be referenced with the variable name major_version.
USB Major Version Number
Minor Version
This property is of type Signed integer and can be referenced with the variable name minor_version.
USB Minor Version Number
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RETURN.
Specifies the way the receive function indicates a timeout.
8 Bit mode - Timeout is represented by the value 255.
16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Enumeration Timeout
This property is of type True or false and can be referenced with the variable name enumeration_tout.
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Transmit Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name TXBUFSZ.
Sets the size of the transmit buffer.
Recommended to be between 8 and 64 bytes.
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name RXBUFSZ.
Sets the size of the receive buffer.
Driver Directory
This property is of type Directory and can be referenced with the variable name driver_directory.
Directory to save the generated device driver .inf file
Driver Filename
This property is of type Line of text and can be referenced with the variable name driver_filename.
Filename to give to the generated driver file.
Generate Driver
This property is of type True or false and can be referenced with the variable name gen_driver.
Generates a driver file when set to Yes, Automatically jumps back to No when complete.
COM Port
This property is of type Fixed list of text and can be referenced with the variable name COM_port.
Hardware COM port to communicate with any connected USB serial devices or any other virtual COM ports.
Text displayed on the I/O flasher comms component.
