API Panel.Position.RotateY
<sidebar>API contents</sidebar> Rotates the object around the Y axis
HANDLE Handle
HANDLE PivotHandle
- An optional position to treat as the origin to rotate around
FLOAT Degrees
- Number of degrees to rotate by
- Add to a calculation icon:
::Panel.Position.RotateY(handle, pivothandle, degrees)
