API Panel.Position.RotateZ
Revision as of 21:21, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Rotates the object around the Z axis
===Class hierarchy===Panel
Position
RotateZ
HANDLE Handle
HANDLE PivotHandle
An optional position to treat as the origin to rotate around
FLOAT Degrees
Number of degrees to rotate by
  • Add to a calculation icon:
    ::Panel.Position.RotateZ(handle, pivothandle, degrees)
