Component: File (SD, SDHC) (Storage)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Author Matrix Ltd.
Version 2.7 (Release)
Category Storage
Image FAT (SD, SDHC) component
FAT component allowing access to read and write files on a SD, SDHC or MMC card.
The component automatically detects the filesystem on the card on initialise so FAT16 and FAT32 are fully supported.
Reading data from a text file
Example to read a text file from a SD card or from a text file in simulation and display on a 16 x 2 character LCD. The text file needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FAT Read File File:Test.txt
Console showing current 512 byte sector data
Console showing high level FAT status
Parsing a standard .BMP image file
Example to read a bitmap image file from a SD card or from a bitmap file in simulation and display on a graphical LCD. The bitmapfile needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FAT display Bitmap Demo bitmap files referenced in the example.
File:FATDemoBitmaps.zip
Picture showing a bitmap being displayed on a GLCD component.
Data logger Simple
Example showing how to take a collection of analogue readings and save them into a text based file, the simple way. FAT data logger simple but slow
Data logger Advanced
Example showing how to take a collection of analogue readings and save them into a text based file, the fast way. FAT data logger fast
Log Keypad Presses
Example showing how to poll a keypad for key presses. Each key press is shown on an LCD and appended to a log file as an ASCII character using the FAT component. Keypad Press Log
Streaming Audio Files
Example showing how to steam out .wav audio files from an SD card using a 16-bit @ 16KHz file format. A free program such as Audacity can be used to create or edit the .wav files. WAV Streaming
ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file.
An empty string signifies the end of the file has been reached.
BYTE NumBytes
Maximum number of bytes to attempt to read
BYTE EndChar
Ends the string if the value specified is found, default is 0
STRING
WriteByteToBuffer
Writes a single byte to the current 512 byte local sector buffer.
UINT Address
Address Range 0 - 511
BYTE Data
Data Byte to write to the buffer
MoveToNextFileSector
Attempts to move to the next sector in the file.
When reading a file you would leave force next sector set to 0.
When writing a file you would leave force next sector set to 1 to allow new sectors to be created as the file grows.
Returns 0 for success
BYTE Force_Next_Sector
0 = Don't add new sector, 1 = Add new sector if we are at the end of the file
BYTE
AppendByteToFile
Adds a single byte to the end of the currently open file, useful for inserting the value 0 into binary file types.
Returns 0 for success.
<- BYTE Data
Data to append to the end of the file
This parameter may be returned back to the caller
BYTE
ReadFileSector
Overwrites local buffer with the current file sector from the disk.
Used to restore the local sector buffer with the actual sector stored on the card.
Return = 0 : Local buffer refreshed with current card sector
Return > 0 : Error
This macro has no parameters
BYTE
ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file.
A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
UINT
DeleteFile
Searches for and deletes a file in the current folder location on the card. Default = Root
<- STRING Filename
8.3 format filename e.g."file.txt"
BYTE
CreateFile
Creates a file in the current folder location on the card. Default = Root
File must be opened using "Open_File" after creation before writing any data.
<- STRING Filename
BYTE
ScanCurrentFolder
Method for retreiving file or folder names for the card to allow for dynamic file opening or playback. Does not currently simulate.
0 - Filetype found and stored into string array, 1 - End of folder reached, 2 - Filetype mismatch 3 - Empty
UINT Current_Idx
Contains the current pointer in the directory table. Values from 0 to 511 to completley search the current folder for a files or folders
BYTE Scan_Type
Sets the scan to search for Files or Folders. 0 = Scan for files, 1 = Scan for folders
BYTE
ReadByteFromScan
Returns a byte of the name of the file or folder retreived from the Scan_Current_folder function.
Return = ASCII byte at position Idx from the folder name or file name at position Current_Idx in the directory
BYTE idx
0 - 11 for a file, 0 - 7 for a folder
BYTE
OpenFolder
".." - Jumps up a directory, if at root then remains in root
"root" - Jumps directly back to the root directory
"foldername" - Opens folder named foldername
<- STRING Folder_Name
BYTE
ReadByteFromBuffer
Reads a byte of data from the local sector buffer.
Return = Data byte read from the local sector buffer.
UINT Address
0 - 511 - Contains the position of the byte to be read
BYTE
ReadFileLength
Returns the number of bytes in the current sector that are used by the current open file.
Return = 512 - Sector is filled with file data
Return < 512 - Last sector of the file, Retval specifies how many bytes of data are remaining in the sector
INT
OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk.
<- STRING Filename
8.3 filename of the file we are trying to open e.g. "file.txt"
BYTE
WriteFileSector
Overwrites the current sector on the memory card with the contents of the local sector buffer. See write_byte_to_buffer function.
Return = 0 - File sector written successfully.
Return > 0 - File sector write error
BYTE
SetFileIndex
Sets the current file index and used to switch between several open file streams.
Default = 0.
BYTE File_Index
File index ranges from 0 to (Max Concurrent Files - 1)
AppendStringToFile
Adds the contents of the data string parameter to the end of the currently open file.
<- STRING Data_String
BYTE
SetTimeAndDate
Sets the current time and date in 16-bit FAT format.
Additional details on the formatting can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat
UINT Time
Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2
UINT Date
Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980
Attempts to communicate with the SD card and if successful sets up the file system.
BYTE
Simulation macro reference
This property is of type Signed integer and can be referenced with the variable name max_concurrent_files.
Specifies how many concurrent files can be opened at any one time.
Use the SetFileIndex macro to switch between concurrent files.
End Of File
This property is of type Fixed list of ints and can be referenced with the variable name EOFtype.
Specifies the way the ReadByteFromFile function indicates the end of a file.
8 Bit mode - End of the file is represented by the value 0, read multiple times to confirm that the 0 is not simply data.
16 Bit mode - End of file is represented by the value 512 allowing the values 0 - 255 to represent valid data.
This property is of type Fixed list of ints and can be referenced with the variable name Channel.
SPI communications channel
Initial Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PR_SCALE.
SPI initial clock divider - Frequency should be under 400khz to allow startup to work correctly.
High Speed Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PR_SCALE2.
SPI high speed clock divider - Once startup is complete this is the rate that will be used to transfer data
Chip Select - CS
This property is of type Single digital pin and can be referenced with the variable name cs_pin.
Chip Select Pin for SPI
Data Out - MOSI / SDO
This property is of type Single digital pin and can be referenced with the variable name mosi_pin.
Data Out SPI Pin
Data In - MISO / SDI
This property is of type Single digital pin and can be referenced with the variable name miso_pin.
Data In SPI Pin
Serial Clock - SCK
This property is of type Single digital pin and can be referenced with the variable name sck_pin.
Master Clock SPI pin
Root Directory
This property is of type Directory and can be referenced with the variable name root_dir.
Directory flagged as root for simulation.
Modern windows systems do not like you writing files to a hard drive root directory so a directory off the root is advised.
Auto Insert Card
This property is of type True or false and can be referenced with the variable name AutoInsertCard.
When set to yes the SD card will be automatically inserted at the start of simulation,
Otherwise you must manually click the card on the panel to insert.
