Component: Bluetooth (EB024, Generic AT) (Wireless)
Revision as of 10:26, 9 May 2018 by BenR (talk | contribs) (XML import)
Author Matrix Ltd.
Version 2.0 (Release)
Category Wireless
Image Bluetooth (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block.
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board. Bluetooth Discover Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD. Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device. Bluetooth Connect The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
StringRead
Returns the ASCII value of character idx of the Response string.
BYTE idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
BYTE
SendScript
Sends Script idx
Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent.
Returns 0 for success and 1 for error
BYTE idx
Refers to the Script page to send (1-4).
BYTE
SendCommand
Sends the command buffer.
Returns 1 for success in sending the command.
Returns 0 for errors.
BYTE ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
BYTE SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
BYTE
CreateCommandString
Assigns a string of characters to the Command buffer.
Returns 1 for success in adding the characters to the buffer.
Returns 0 for errors, including Buffer overflow.
<- STRING Data
This parameter may be returned back to the caller
BYTE
StringReceive
Checks for a response string.
Returns the length of the response string if one is present otherwise returns 0.
This macro has no parameters
BYTE
CreateCommand
Adds a single characters to the end of the Command buffer.
BYTE Character
ASCII value or single character,
BYTE
Send_byte
BYTE ByteVal
WaitForResponse
Waits for a response message of type response_code for timeout ms.
Returns: 0 for a Response of type response_code
255 (0xFF) for a timeout or invalid response
Response string length for any Response not of type response_code
BYTE response_code
1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
BYTE timeout
The timeout value will need to set to allow sufficient time for the response to arrive.
BYTE
Required to be used whenever the Bluetooth component is used in a program.
Initialises the Bluetooth component ready for use.
Simulation macro reference
Command Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name CommandBufferSize.
Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ResponseBufferSize.
Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name SCRIPTS.
Controls how many AT scripts are stored into non-volatile memory
Script 1
This property is of type Multiple lines of text and can be referenced with the variable name SCRIPT1.
Data to send for script 0, each command should be terminated with a carriage return
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
Use Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::FLOWEN.
Flow Control (Handshake) enable or disable.
   On: Two I/O pins are used to control the flow of data in and out of the device.
   Off: Flow control is disabled.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
   Simulation - draws an approximation of the UART data onto the scope trace.
   ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
   Nothing - Simulation data is ignored
   COM port - Routes the communication data to and from a physical or virtual COM port
   Injector - Routes the communication data via a data injector component on the Panel.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::Injector.
Selects which injector component to route the communication data via.
Add injector components to the panel before they will be available in this list.
Injector components are available from the Comms component category.
