Component: Bluetooth v2 (EB024, Generic AT) (Wireless)
Revision as of 10:26, 9 May 2018 by BenR (talk | contribs) (XML import)
Author Matrix Ltd.
Version 2.0 (Release)
Category Wireless
Image Bluetooth v2 (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware channel.
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board. Bluetooth Discover Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD. Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device. Bluetooth Connect The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
SetPairKey
Sets the 4 digit Bluetooth pair key based on a string of numbers.
e.g. "1234"
Returns 0 to indicate success
<- STRING PairKey
Key to use as the Pair key, e.g. "1234" or "0000"
This parameter may be returned back to the caller
BYTE
ReceiveByte
Receives a single data byte from the Bluetooth module.
0xFF signifies no data available.
BYTE Timeout
Amount of time to wait in milliseconds 0=Wait forever
BYTE
SendString
Sends a string to the GSM module.
<- STRING Command
BYTE SendCR
SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
BYTE idx
BYTE
SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
<- STRING Command
BYTE SendCR
BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
BYTE
ReadString
Copies the incoming data from the data string array to a local string variable.
BYTE NumBytes
STRING
SaveSettings
Saves the current settings to firmware using the AT&W command followed by the ATZ command.
This macro has no parameters
BYTE
SendByte
Sends a single data byte out to the Bluetooth module.
BYTE Data
SetMode
Sets the bluetooth mode to be discoverable and or connectable.
Returns 0 for success.
BYTE Discoverable
0 = Not Discoverable, 1 = Discoverable
BYTE Connectable
0 = Not Connectable, 1 = Connectable
BYTE
RestoreFactorySettings
Restores the factory settings to firmware using the AT&F* command.
BYTE
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
BYTE
Simulation macro reference
String Array Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responses from the BT module.
Default 40
Expect Echo
This property is of type True or false and can be referenced with the variable name expect_echo.
Sets if we expect an echo of any data we send out to the GSM modem.
Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
Device Name
This property is of type Line of text and can be referenced with the variable name DeviceName.
Sets the friendly name of the Bluetooth device.
Pair Key
This property is of type Line of text and can be referenced with the variable name PairKey.
Restore Defaults
This property is of type True or false and can be referenced with the variable name InitDefs.
Is the Bluetooth module reset to factory settings at startup?
Discoverable
This property is of type True or false and can be referenced with the variable name InitDisc.
Is the Bluetooth module discoverable by default?
Connectable
This property is of type True or false and can be referenced with the variable name InitConn.
Is the Bluetooth module connectable by default?
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Maximum number of scripts to store in the device's ROM
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
ASCII based AT command data stored in ROM and used when sending script 1
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
Use Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::FLOWEN.
Flow Control (Handshake) enable or disable.
   On: Two I/O pins are used to control the flow of data in and out of the device.
   Off: Flow control is disabled.
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name Reset.
Textual label shown on the component I/O flasher
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
   Simulation - draws an approximation of the UART data onto the scope trace.
   ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
   Nothing - Simulation data is ignored
   COM port - Routes the communication data to and from a physical or virtual COM port
   Injector - Routes the communication data via a data injector component on the Panel.
