Component: FCD helper (Matrix Tools)
Revision as of 10:27, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Matrix Tools
Image FCD helper component
A helper control to query the current FCD file
This component does not contain any downloadable macros
Simulation macro reference
GetStrListItem
Gets a list item from a string index and a textual name
Suitable for writing to a property filter
Newline is added
STRING Index
STRING Name
STRING
GetIntListItem
Gets a list item from an integer and a textual name
Newline is added
UINT Index
STRING Name
STRING
Register
Registers a property to update when the FCD changes
HANDLE Dest
STRING PropName
STRING FCDPath
UINT INdex
A zero based index of the path to find
STRING IxAttr
STRING NameAttr
GetPropertyList
Gets a filter list suitable for adding to a property
Uses the [u]IxName[/u] as the index into the list
Uses the [u]Text[/u] as the line to show in list-boxes
STRING FCDPath
UINT Index
STRING IxName
STRING Text
STRING
This component does not contain any properties
