Component: Airplane Landing Gear (Scenarios)
Revision as of 10:31, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Scenarios
Image Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
This component does not contain any downloadable macros
Simulation macro reference
FrontDoors
Will allow the front doors to open.
BYTE Direction
Drops the door down or close them. 0 = Close 1 = Open
FrontDoorCloseSwitch
Test to see if the Front door will touch the collision switch by its original position. If it does, will return true. and stop movement.
Assigned variable of a Bool is recommended
This macro has no parameters
BYTE
LandingGearDownSwitch
Test to see if the Landing Gear will touch the collision switch by its final position. If it does, will return true. and stop movement.
BYTE
RearDoorLocks
Will unlock or lock the rear doors
BYTE OpenOrClose
Open =1 Close =0
LandingGearUpSwitch
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement.
BYTE
FrontDoorOpenSwitch
Test to see if the Back door will touch the collision switch by its final position. If it does, will return true. and stop movement.
BYTE
FrontDoorLocks
Will lock or unlock the front doors depending on the number given to the paremeter.
BYTE OpenOrClose
Open =1 Close=0
LandingGear
Retracts and drops the landing gear.
BYTE Direction
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop
RearDoorCloseSwitch
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement.
BYTE
RearDoors
Will allow the rear door to open
BYTE Direction
Drop the door down or close them. 0 = Close 1 = Open
RearDoorOpenSwitch
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement.
BYTE
This component does not contain any properties
