Component: Proximity Analog Template (Sensors)
| Author | Matrix Ltd |
| Version | 1.2 (Release) |
| Category | Sensors |
Polls a chosen panel object to test it's distance from this component. When the test object is within the detection range, the state of a pin is changed, and a User event generated. Used for building models of reed swicthes and hall sensors.
ReadState
Get the current collision state.
The 'Polarity' property will affect whether a collision is represented by a high
or low state.
WaitUntilHigh
Pause the program until the detector goes high.
'Polarity' will affect whether high value represents a collision or separation.
NB) In simulation, only use this macro if testing for collision with animated or
timer driven objects!!
WaitUntilLow
Pause the program until the detector goes low.
'Polarity' will affect whether low value represents a collision or separation.
Simulation macro reference
SetTarget
Set the object that you want to test for collision with.
If this is not called, or is called with handle = 0, collisions will be tested against
every panel object that has 'Solid' status.
NB) Specifying an object will save CPU power!!
- HANDLE Target
- The object to test for collision with.
Pin
This property is of type Single digital pin and can be referenced with the variable name pin.
The chip pin that will receive the switch state.
Polarity
This property is of type Fixed list of ints and can be referenced with the variable name polarity.
Select the state that the switch will take when an object triggers the switch.
Datum Object
This property is of type Panel object and can be referenced with the variable name test_object.
The object within the component from which the distance to the target object will be measured.
If not set, the centre of the component as a whole will be assumed.
Range
This property is of type Floating point and can be referenced with the variable name range.
Distance within which the switch is activated.
NB) This is measured between the centre of the proximity switch and the centre of the target object.
Mouse Object
This property is of type Panel object and can be referenced with the variable name mouse_object.
Choose an object within the component that the user can click on to activate the switch for testing purposes.
Detector Ident
This property is of type Unsigned integer and can be referenced with the variable name event_id.
An ID value to identify this particular detector. Will be sent as the 'Ident' value for the notification
events sent out so that multiple detectors can be told apart.
The event value will be 1 for actiavted and 0 for de-activated,
Timer Interval (ms)
This property is of type Unsigned integer and can be referenced with the variable name timer_int.
Time in milliseconds between testing for proximity.
Small time = Greater CPU load
Large time = More like to miss activation if it is very brief.
