Component: Accelerometer (EB068) (E-blocks 1)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 2.0 (Release)
Category E-blocks 1
Image Accelerometer (EB068) component
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. Useful for approximating Pitch and Roll or for detecting acceleration. Also available in the form of the EB068 Accelerometer E-block.
CollectXYZData
Collect the data from the local accelerometer buffers.
The Axis parameter specifies the Axis to be read.
0 / 'x' / 'X' - X axis
1 / 'y' / 'Y' - Y axis
2 / 'z' / 'Z' - Z axis
BYTE Axis
INT
UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables.
Returns 1 for new data and 0 for no new data
This macro has no parameters
BYTE
Sets up up the communication bus and initialises the accelerometer module.
Returns 0 for success and > 0 for fail.
BYTE
Simulation macro reference
SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was
sitting completely horizontal.
SimSetXYZ
Allows the XYZ slider values to be set via the simulation
INT X
INT Y
INT Z
Bit Depth
This property is of type Signed integer and can be referenced with the variable name bit_depth.
The number of binary bits used to store the sensor's X,Y,Z readings.
Bus Type
This property is of type Fixed list of ints and can be referenced with the variable name bus_type.
The interface used to talk to the accelerometer.
I2C - Two Wire Interface SDA / SCL
SPI - Four Wire Interface MISO / MOSI / SCK / CS
Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name data_rate.
Configures how often the sensor collects a new reading.
More often = better instant reaction to new events
Less often = more stable results
Scale
This property is of type Fixed list of ints and can be referenced with the variable name scale.
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent.
6G = Bigger gravitational force
2G = Higher resolution
Int Option
This property is of type Fixed list of ints and can be referenced with the variable name IntOpt.
Sets if we use the interrupt pin to check if new data is available
Power Option
This property is of type Fixed list of ints and can be referenced with the variable name PowerOpt.
Sets if the sensor is always powered or powered via a microcontroller output pin.
Interrupt Pin
This property is of type Single digital pin and can be referenced with the variable name int_pin.
Interrupt pin from the sensor, checked when performing an update to see if the sensor has new data available.
Power Pin
This property is of type Single digital pin and can be referenced with the variable name pwr_pin.
Power pin if the sensor is powered from an I/O pin.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c::BAUD.
Baud rate to be used
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SCL.
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulation GUI
This property is of type True or false and can be referenced with the variable name SimulationGUI.
Yes: Accelerometer data will come from the simulation component sliders.
No: Accelerometer data will come from the CAL component - I2C or SPI - Injector etc
This property is of type True or false and can be referenced with the variable name cal_i2c::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::Injector.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
