Component: Combo (BL0114) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Seg_ShowDigit
Displays a digit on the 7-seg display
- BYTE Digit
- Which of the digits to change (0 - 3)
- BYTE Value
- The value to display (0 - 9)
- BYTE DecimalPoint
- Decides if the decimal point is lit
LCD_PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- Enter the number or variable to print to the LCD
- BOOL Format
- 0=Signed, 1=Unsigned
LCD_RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
- Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
- Character to look for a replace
- BYTE ReplacementCharacter
- New character value to use in place of the search character.
LCD_ScrollDisplay
- BYTE Position
- Holds the number of positions to shift the display
- BYTE Direction
- 0 = left, 1 = right
IO_SetPort
Sets the state of a single port
- BYTE Bank
- 0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
- BYTE Value
IO_SetLEDState
Sets the state of a single LED
- BYTE Bank
- BYTE LED
- 0 = LED0, 7 = LED7
- BYTE State
- 0 = Off, 1 = On
IO_GetPort
Reads the state of a single port
- BYTE Bank
- 0 = Top Bank of Switches, 1 = Bottom Bank of Switches
LCD_Cursor
- BYTE x
- Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
- Set the cursor position in the Y plane, 0 is the top most cell
LCD_Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
LCD_Command
- BYTE instruction
- Send a defined command to the LCD Screen. See datasheet for supported commands.
LCD_RAMWrite
- BYTE Index
- Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
IO_ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
- 0 = Light Sensor, 1 = Potentiometer
LCD_PrintString
- <- STRING Text
- Enter the text or variable to print to the LCD
LCD_ClearLine
- BYTE Line
- The line to clear, zero being the first (top) line of the display
IO_GetSwitchState
Reads the state of a single switch
Returns: 0 = Switch not pressed, 1 = Switch pressed
- BYTE Bank
- BYTE Switch
- 0 = SW0, 7 = SW7
IO_ReadAnalogAsByte
Reads one of the analogue components as an byte value
- BYTE Channel
LCD_PrintAscii
- BYTE character
- Holds an ascii value.
LCD_PrintNumber
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
LCD_RawSend
Sends data to the LCD display
- BYTE data
- The data byte to send to the LCD
- BOOL type
- A boolean to indicate command type: true to write data, false to write a command
LCD_Clear
Simulation macro reference
Connection Type
This property is of type Fixed list of ints and can be referenced with the variable name ConnType.
Bank 0
This property is of type Digital port byte and can be referenced with the variable name Bank0.
Bank 1
This property is of type Digital port byte and can be referenced with the variable name Bank1.
