Component: GLCD (BL0139) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
GLCD (BL0139) component
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Compatible with the EB2 BL0139 Downstream E-block.
- INT Number
- Byte or Integer number to send to the display.
- UINT X
- X pixel coordinate to set the output string position.
- UINT Y
- Y pixel coordinate to set the output string position.
- BYTE Font
- Range: 0 to 31 - 0=5x8, 1=10x8, 2=10x16, 3=5x16, 4-31=Extended Sizes
- BYTE Transparent
- Specifies if the background of the text is drawn - 0 = Background colour is drawn, 1 = Background colour not drawn.
DrawLine
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
Write_Data
- BYTE data
Goto_XY
- BYTE X
- BYTE Y
Plot
- BYTE X1
- BYTE Y1
DrawEllipse
- UINT X
- X Coordinate for the center of the circle
- UINT Y
- Y coordinate for the center of the circle
- UINT XRadius
- Radius of the circle on the X axis specified in pixels
- UINT YRadius
- Radius of the circle on the Y axis specified in pixels
- BYTE Transparent
- 0=Fill inside circle using background colour / 1=Draw outer circle only
- BYTE Solid
- 0=Use Transparent Setting / 1=Fill with foreground colour
SetDisplayOrientation
- BYTE Orientation
- 0=Default, 1=90°CW, 2=180°CW, 3=270°CW
BPlot
- BYTE X1
- BYTE Y1
- <- STRING Str
- String of characters to send to the display.
- UINT X1
- UINT Y1
- Y coordinate 0-31
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
- 0=White, 1=Black
Write_Command
- BYTE Command
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- Radius of the circle specified in pixels
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
- 0=White, 1=Black
DrawRectangle
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE Transparent
- BYTE Solid
Simulation macro reference
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Color Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Data Pin
This property is of type Single digital pin and can be referenced with the variable name data_pin.
Clock Pin
This property is of type Single digital pin and can be referenced with the variable name clock_pin.
A0
This property is of type Single digital pin and can be referenced with the variable name a0_pin.
CS
This property is of type Single digital pin and can be referenced with the variable name chip_sel_pin.
Chip select pin
Reset
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
LCDVersion
This property is of type Fixed list of ints and can be referenced with the variable name LCDVersion.
