Component: GLCD (EB057 / EB058) (E-blocks 1)
| Version | 2.0 (Release) |
| Category | E-blocks 1 |
GLCD (EB057 / EB058) component
Graphical display component designed to work with the EB057 modules and EB058 E-blocks.
- INT Number
- Byte or Integer number to send to the display.
- UINT X
- X pixel coordinate to set the output string position.
- UINT Y
- Y pixel coordinate to set the output string position.
- BYTE Font
- Range: 0 to 31 - 0=5x8, 1=10x8, 2=10x16, 3=5x16, 4-31=Extended Sizes
- BYTE Transparent
- Specifies if the background of the text is drawn - 0 = Background colour is drawn, 1 = Background colour not drawn.
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
- UINT X1
- UINT Y1
DrawEllipse
- UINT X
- X Coordinate for the center of the circle
- UINT Y
- Y coordinate for the center of the circle
- UINT XRadius
- Radius of the circle on the X axis specified in pixels
- UINT YRadius
- Radius of the circle on the Y axis specified in pixels
- BYTE Transparent
- 0=Fill inside circle using background colour / 1=Draw outer circle only
- BYTE Solid
- 0=Use Transparent Setting / 1=Fill with foreground colour
SetDisplayOrientation
- BYTE Orientation
- 0=Default, 1=90°CW, 2=180°CW, 3=270°CW
BPlot
- UINT X1
- UINT Y1
- <- STRING Str
- String of characters to send to the display.
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- 0 - 255 where 0 = no red and 255 = maximum red
- BYTE Green
- 0 - 255 where 0 = no green and 255 = maximum green
- BYTE Blue
- 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- Radius of the circle specified in pixels
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data.
- BYTE Solid
- Chooses to fill the box with colour - 0 = Box contains transparency data, 1 = Box contains foreground colour.
Simulation macro reference
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Color Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
