Component: IO Expander (BL0155) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
IO Expander (BL0155) component
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
ReadPort
Reads a value to one of the ports with a mask.
Configures the masked bits to be inputs before reading the input value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Mask
- Allows port bits to be modified without effecting other bits, 255 = write full port.
ConfigureInversion
Configures the pin inversion for the two ports.
Disabled on all pins by default.
- BYTE PortA
- Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
- Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
Reads a single port pin from one of the ports.
Configures the pins to be an input before reading the input value.
Returns 0 or 1 corresponding to the value on the port pin.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Pin
- Port pin to read. Range: 0-7
WritePortPin
Writes a single port pin on one of the ports.
Configures the pins to be an output before writing the input value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Pin
- BYTE Value
- Value to output on the selected pin. Range: 0-1
WritePort
Writes a value to one of the ports with a mask.
Configures the masked bits to be outputs before writing the output value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Mask
- BYTE Value
- Value to write. Range 0-255
ConfigurePullups
Configures the pullups for the two ports.
- BYTE PortA
- Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
- Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE Address
- Register address to write to. Range: 0-15
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE Address
- BYTE Value
- Value to write. Range: 0-255
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
