Component: SRF (WirelessThings) (SRF) (Wireless)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author MatrixTSL
Version 1.0 (Release)
Category Wireless
Image SRF (WirelessThings) (SRF) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
SendString
Send a string of data using the SRF Module
STRING Data
Wake
Wake the SRF module. Includes a 10ms delay to allow radio to wake.
This macro has no parameters
SendChar
INT Char
Sleep
Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending)
SRFInitialise
Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping.
ReceiveString
BYTE Timeout
BYTE NumBytes
STRING
ReceiveChar
BYTE Timeout
INT
Simulation macro reference
Sleep Mode (ATSM)
This property is of type Fixed list of ints and can be referenced with the variable name ATSM.
Defines which sleep mode will be used when calling the Sleep component macro.
This property is of type Fixed list of ints and can be referenced with the variable name Baud_Rate.
Serial comms data rate specified in bits per second.
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Onboard UART peripheral to use to perform serial commands.
Software mode available but not recommended for receive applications unless combined with a pin interrupt.
TX
This property is of type Single digital pin and can be referenced with the variable name TxPin.
Serial data transmit pin, output from the target microcontroller and should be connected to the RX pin of the module.
RX
This property is of type Single digital pin and can be referenced with the variable name RxPin.
Serial data receive pin, input to the target microcontroller and should be connected to the TX pin of the module.
Sleep
This property is of type Single digital pin and can be referenced with the variable name Sleep_Pin.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to COM port hardware or the the data injector components.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name com_port.
Lists all the current available COM port hardware on your PC.
