API File.Buffer
Revision as of 22:11, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Reads writes and monitors circular buffers This class is contained within File
Functions provided for this class
Open Opens the existing file as a circular buffer
Create Creates the new file as a circular buffer
ReadByte Reads a single byte from the input stream, -1 if empty
WriteByte Writes a single byte to the input stream
ReadArray Reads an array from the input stream, returns elements read
WriteArray Writes an array to the input stream
See also
