Component: Car Seat (Scenarios)
Version 1.0 (Release)
Category Scenarios
Image Car Seat component
An electric car seat chassis with a series of motors and sensors. Students should work through exercises to learn the principles of electric car seats including how to save and load memory positions.
Car Seat Scenario
This component does not contain any downloadable macros
Simulation macro reference
Save
BYTE SavePos
0 = pos A, 1 = pos B
Load
BYTE Location
0 = A, 1 = B
Encoder3
Returns value is equal to Rear Z Axis current value.
This macro has no parameters
INT
Encoder2
Returns value is equal to Front Z Axis current value.
INT
Encoder1
Returns value is equal to X Axis current value (forward/ backwards movement).
INT
CurrentSenseMotor3
This macro is used to sense the current draw from DC motor 3. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
BYTE
CurrentSenseMotor2
This macro is used to sense the current draw from DC motor 2. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
BYTE
Motor3
Controls the Movement of the seat going up and down by the back
BYTE Direction
0 = Stop, 1 = Up, 2 = Down
CurrentSenseMotor1
This macro is used to sense the current draw from DC motor 1. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
BYTE
Motor2
Controls the Movement of the seat going up and down by the front
BYTE Direction
Motor1
Moves the Car Seat Forwards and Backwards
BYTE Direction
0 = Stop, 1 = Forward, 2 = Backward
Show seat base?
This property is of type Fixed list of ints and can be referenced with the variable name Show_Hide.
Controls if the base of the car seat is shown on the simulation panel.
