Component: RFID (MFRC522) (Wireless)
Revision as of 14:26, 8 June 2018 by BenR (talk | contribs)
Author Ben Rowland and STibor
Version 3.0 (Release)
Category Wireless
Image RFID (MFRC522) component
Functions designed to work with the MFRC522 contactless reader IC. The MFRC522 supports all variants of the MIFARE Mini, MIFARE 1K, MIFARE 4K, MIFARE Ultralight, MIFARE DESFire EV1 and MIFARE Plus RF identification protocols.
Here is a basic example program that reads the UID from a Mifare RFID tag and displays on an LCD. If the UID matches the UID stored in memory then a solenoid will fire allowing a door to be unlocked etc.
Display UID
Here is a basic example program to read and modify data stored on a Mifare RFID tag.
Read Write Test
CompareUID
Compares the UID from the ReadCardSerial macro with 4 byte UID.
Returns 0 if the addresses match.
BYTE Add0
BYTE Add1
BYTE Add2
BYTE Add3
BYTE
IsNewCardPresent
Is there a card present for us to communicate with.
Returns 0 for no card and 1 for valid card present.
This macro has no parameters
BYTE
GetType
Translates the SAK (Select Acknowledge) to a PICC type
BYTE sak
The SAK byte returned from PICC_Select
BYTE
AntennaOff
Switches off the RFID antenna to save power.
The antenna must be switched on again before communicating with an RFID tag.
ReadCardSerial
Simple wrapper around PICC_Select.
Returns true if a UID could be read.
Remember to call PICC_IsNewCardPresent(), PICC_RequestA() or PICC_WakeupA() first.
The read UID is available in the class variable uid.
BYTE
MifareWrite
Writes to a block of data on a MIFARE type tag
BYTE BlockAddress
BYTE Buffer
BYTE BufferSize
BYTE
Select
BYTE ValidBits
BYTE
StopCrypto
Used to exit the PCD from its authenticated state.
Remember to call this function after communicating with an authenticated PICC - otherwise no new communications can start.
MifareRead
Reads from a block of data on a MIFARE type tag
BYTE BlockAddress
BYTE Buffer
BYTE BufferSize
BYTE
Authenticate
This command manages MIFARE authentication to enable a secure communication to any MIFARE Mini, MIFARE 1K and MIFARE 4K card.
All keys are set to FFFFFFFFFFFFh at chip delivery.
The authentication is described in the MFRC522 datasheet section 10.3.1.9.
BYTE Command
PICC_CMD_MF_AUTH_KEY_A or PICC_CMD_MF_AUTH_KEY_B
BYTE BlockAddress
The block number
BYTE Key
Crypteo key to use
BYTE
HaltA
Instructs a PICC in state ACTIVE(*) to go to state HALT
BYTE
ReadUIDByte
BYTE Index
0-9 = UID Data Bytes, 10 = UID Length, 11 = UID SAK
BYTE
AntennaOn
Switches on the RFID antenna.
Called as part of the Initialise macro.
Initialises the RFID module ready for interaction with RFID tags.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset
This property is of type Single digital pin and can be referenced with the variable name reset.
MFRC522 Reset Pin
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
