Component: Bluetooth (BL0170) (E-blocks 2)
| Author | Matrix Ltd. |
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
 Bluetooth (BL0170) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
ReceiveByte
Receives a single data byte from the Bluetooth module.
0xFF signifies no data available.
- UINT Timeout
- Amount of time to wait in milliseconds 0=Wait forever
SendString
Sends a string to the GSM module.
- <- STRING Command
- BYTE SendCR
ReadString
Copies the incoming data from the data string array to a local string variable.
- BYTE NumBytes
- Maximum number of bytes to try and read
SendByte
Sends a single data byte out to the Bluetooth module.
- BYTE Data
Sets up the Bluetooth module including:
- Enabling the UART
- Configuring the module (Name / Key / etc)
Returns 1 for OK and 0 for no reply.
Simulation macro reference
Device Name
This property is of type Line of text and can be referenced with the variable name DeviceName.
Sets the friendly name of the Bluetooth device.
Pair Key
This property is of type Line of text and can be referenced with the variable name PairKey.
Discoverable
This property is of type True or false and can be referenced with the variable name InitDisc.
Is the Bluetooth module discoverable by default?
Reply Timeout
This property is of type Unsigned integer and can be referenced with the variable name ReplyTimeout.
Specifies the amount of time to wait for incoming data before timing out in milliseconds.
Default 2000 = 2 seconds.
RX Buffer Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module.
Default 40
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
TX Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::OutputPins.
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
RX Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::InputPins.
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Use Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::FLOWEN.
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device.
Off: Flow control is disabled.
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name Reset.
Textual label shown on the component I/O flasher
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
Simulation - draws an approximation of the UART data onto the scope trace.
ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
