Component: Ultrasonic (EBM019) (EBM Modules)
Revision as of 10:06, 22 October 2018 by BenR (talk | contribs)
Version 1.0 (Release)
Category EBM Modules
Image Ultrasonic (EBM019) component
This board has both an ultrasonic transmitter and receiver. The transmitter is driven by an on-board 40KHz oscillator which is enabled by the host microprocessor. The receiving sensor signal is amplified and provided as an analogue signal to be processed by a single channel ADC of the microprocessor. By measuring the time delay between enabling a transmit pulse and receiving an echo the distance of objects in a range of around 3cm to 3m can be determined.
Sample program using the EBM019 - Ultrasonic sensor.
Sends out a pulse and determines distance from time taken to receive reflection.
EBM019 Example
GetDistance
Sends a pulse and processes the echo.
Returns a object distance in cm
This macro has no parameters
UINT
SetDelayTime
Set the delay time before sampling for the echo, in microseconds
UINT delay
delay time in microseconds
SetDetectionValue
Set the delta value for echo detection
BYTE value
trigger point for echo detection
SetPulseWidth
Set the output pulse width, in microsecond (0-255uS)
BYTE pulse
width of pulse in microseconds
Setup the device.
This sets the control output to logic 0
Simulation macro reference
Output Pulse Pin
This property is of type Single digital pin and can be referenced with the variable name OPP.
Pin used for controlling the output pulse
Echo ADC channel
This property is of type Single analog pin and can be referenced with the variable name ECHO.
ADC channel used to monitor the echo
Pulse Width (uS)
This property is of type Unsigned integer and can be referenced with the variable name PULSE.
Output ultrasonic pulse width in microseconds
Read Delay (uS)
This property is of type Unsigned integer and can be referenced with the variable name DELAY.
Time delay in microseconds before sampling for echo
Pulse Detection Value
This property is of type Unsigned integer and can be referenced with the variable name THRESHOLD.
Detection ADC delta trigger value
A lower value is more sensitive
