Component: Indicator Meter (Indicators)
| Version | 1.5 (Development) |
| Category | Indicators |
Indicator Meter component
Square analogue panel meter. A simulation only component - the needle value is set solely by the 'SetValue' macro.
This component does not contain any downloadable macros
Simulation macro reference
SetValue
Set the meter needle to a new position based on the current scaling properties.
- FLOAT Value
- Needle position between min and max
Minimum
This property is of type Floating point and can be referenced with the variable name val_min.
Minimum value to show on the meter.
Maximum
This property is of type Floating point and can be referenced with the variable name val_max.
Maximum value to show on the meter.
BG Color
This property is of type Color picker with transparency and can be referenced with the variable name bg_color.
Color of the meter scale background.
Positive Color
This property is of type Color picker and can be referenced with the variable name ink_color.
Color of the scale gradations for positive values.
Negative Color
This property is of type Color picker and can be referenced with the variable name neg_color.
Color of the scale gradations for negative values.
Pointer Color
This property is of type Color picker and can be referenced with the variable name NeedleColor.
Label Color
This property is of type Color picker and can be referenced with the variable name label_color.
Color of the meter's title label.
Divisions
This property is of type Signed integer and can be referenced with the variable name marks_count.
Number of large scale divisions..
Subdivisions
This property is of type Signed integer and can be referenced with the variable name marks_subdiv.
Number of sub-divisions in between each major division.
Show
This property is of type True or false and can be referenced with the variable name show_marks.
Show or hide the scale markings.
Decimals
This property is of type Signed integer and can be referenced with the variable name dec_places.
Number of decimal points to show on scale values.
Text Size %
This property is of type Signed integer and can be referenced with the variable name num_size.
Text height of the scale values.
Font
This property is of type Font picker and can be referenced with the variable name num_font.
Font for the scale value numbers.
Show
This property is of type True or false and can be referenced with the variable name show_numbers.
Show or hide the scale number values.
Text
This property is of type Line of text and can be referenced with the variable name label_text.
A title label to make the meter easier to identify.
Text Size %
This property is of type Signed integer and can be referenced with the variable name label_size.
Height of the label text.
Font
This property is of type Font picker and can be referenced with the variable name label_font.
Font for printing the label.
Show
This property is of type True or false and can be referenced with the variable name show_label.
Show or hide the title label.
